Roman Opus Floor Tiling in NexusCad - Printable Version
+- Kitchen Fitters Forum (http://www.kitchenfittersforum.com)
+-- Forum: CAD Section - Help, Advice and Users Tips (http://www.kitchenfittersforum.com/forumdisplay.php?fid=120)
+--- Forum: NexusCad (http://www.kitchenfittersforum.com/forumdisplay.php?fid=123)
+--- Thread: Roman Opus Floor Tiling in NexusCad (/showthread.php?tid=6923)
Roman Opus Floor Tiling in NexusCad - Stretch - 05-02-2017
We finished a kitchen recently where the customer was having the floor tiled in a Roman Opus pattern. At The time, I couldn't show this on the design pics because there is no facility in Nexus to do anything other than linear or brickwork tiling.
However, I've had a play around this afternoon and come up with the following - for anyone who is interested!!
 Th_ROFLMAO
Ok, firstly you need to create a new room and then 10 tiles of different sizes:
2@ 600mm x 400mm
4@ 400mm x 400mm
2@ 400mm x 200mm
4@ 200mm x 200mm
From the Miscellaneous menu select Tiles and drag into the planning area
[attachment=1389]
Change it's Properties to 600 x 400 x 10mm
[attachment=1390]
You can change the Image Texture here or just do it from the options menu but remember to uncheck the Tile Finish option.
[attachment=1391]
Repeat until you have all 10 tiles:
[attachment=1392]
Drag and snap each individual tile into the Roman Opus pattern and then Ctrl-Click them all so they are highlighted.
Now go to File>Save Selection and save it under whatever you like, eg Roman Opus.
[attachment=1393]
Keeping them highlighted, drag them into position, then Ctrl-Click to Copy and Paste so that you create a new set. Alternatively you can just go to File>Merge File and import the selection you saved each time.
[attachment=1394]
Repeat until you've covered the floor:
[attachment=1395]
And then just drag individual tiles to fill the gaps - or leave unfilled if you know they will be covered by units.
[attachment=1396]
And it should look like this!! Thanks for reading. ThumbUp
[attachment=1397]
RE: Roman Opus Floor Tiling in NexusCad - andy5405 - 09-02-2017
Nice idea but you do need to get out more!
RE: Roman Opus Floor Tiling in NexusCad - Stretch - 09-02-2017
And you need to go to bed earlier!
